Let's say between brushing teeth and washing hands, you used 5 gal.
That leaves 27gal...so a little over 5.5 gal for 5 showers will use up the rest.
If you are intense about it, you could probably reduce the usage to 3-4gal per shower but at some point, it's no fun being dirty.
Putting a removable blade valve (you can buy them for about $25 and there is no installation needed) on the main outlet and then opening the valves so it equalizes between the 2 gray and 1 black tank will likely buy you at least a couple more days.
