time2roll
Aug 20, 2018Nomad
Robert Kesselring wrote:OK now put your meter directly on the inverter 12v terminals and monitor again. Please post the results.
I monitored my 12 volt supply while doing this, and it never even flickered, 13.5 to 14 volts the whole time (engine running) I took the AC unit into the house to see if it would run from a mains outlet, and it does.
Was any fault code given by the inverter?
BTW... Tripp-Lite manual really calls for 2/0 wire and a 250 amp fuse. Did not see a battery size but Xantrex would recommend 400+ amp hours.
http://www.genuinedealz.com/custom-cables
About RV Newbies
