pianotuna
Aug 20, 2018Nomad III
Hi,
Not enough battery capacity and/or wire that is too small (on the dc side) connected to an inverter that is simply not large enough.
I was able to run the roof air on a 2500 watt Cobra MSW inverter (rated to run motors). Sometimes I would have to turn on another load first to "wake up" the inverter. I had 7 marine jars totaling 875 amp-hours. That works out to a little over 25 amps of demand per cell.
At the time I did not have a Microair unit.
I could run the roof air on the Magnum 3012, before adding the Microair--but Magnum does not recommend this be done.
If I were to do it again I'd jump to a 48 volt battery bank and a 4400 watt inverter/charger. I think I'd choose Victron, too.
Until there is more capacity and a bigger psw inverter adding a microair may only lighten your pocket book.
About RV Newbies
