wa8yxm
Aug 21, 2018Explorer III
Robert wrote:
\ 8.8 amperes at 115 volts. My inverter is an 1800 watt trip lite that I have had installed in my truck for several years.
that 8.8 amps (a bit over 1100 watts) is RUNNING Starting power is easily 2x or more that for the compressor (like 4-5X) so your inverter is simply NOT big enough.
Another thing to consider. that A/C running sucks over 1,000 watts in an hour. a pair of GC-2 Batteries holds about 1,000 usable watts at the 20 hour rate. at the rate you are sucking power with the A/C that is just a few minutes.
About RV Newbies
