MJO21ExplorerNov 27, 2013Heated tanks???Next question from the newbie. I have heated tanks that I can plug in. I do not plan on taking on fresh water but will have a gray and black tanks that will be used. Should I plug in the tanks on ...Show More
K_CharlesExplorerNov 27, 2013Most tank heaters say not to turn on if tank is empty, but as said above you don't need to heat an empty tank.
Related ContentSouthwind heated tanksHeated tanks?Heated tanksRecycling engine heat for hot water tankHeated tanks
