RoyB wrote:
One of these TC-3 Thermo cube units available from AMAZON should help you out.
THERMO CUBE
This comes on at 35 degrees and goes off at 45 degrees. They have different models for different ON/OFF temperature ranges...
I have that exact same Thermo-Cube, IT is outside the MH (Under it in a rain protected area, supposed to rain today) and plugged into it is a rope light which is taped to my fresh hose, on the end of that is 150 watts of heater or 100 watts of light bulb inside a rip-stop Nylong bag dropped over the park water faucet. Keeps everyitng nice and liquid at 20...
At six.. No such joy.
In the wet bay next to and under the fresh water tank is a competitor's product I got at I think Home Depot. it's bright yellor or orange (Forget which) and has but one outlet.. It feeds a string of C-9 Christmas tree lamps (About 270 watts as I recall) and a 100 watt lamp in a cage which is in the black/gray end of the bay.
My furnace pumps warm air down into the bay as well.
When it hit 11 a week ago,,, I had one water line that froze,, Tanks remained liquid, no fittings were frozen, just the middle of a PEX run (The pex is in that bay but I figure without a lot of air moving about it froze right about where it crosses over the drive shaft) only one of the two lines there froze.. So to flush I grabbed my six cup measure and filled with HOT water from the sink and dumped it in.
Soon as the sun came up the line thawed and normal operation continued,, Water heater (Operating) did not, of course, freeze.
Man was I glad to be on a 50 amp site.
Now Im back on a 30+30 site.
