dcmac214's avatar
dcmac214
HELP! - TV Mice/Rats Question
What can be done to keep mice/rats from eating vehicle wiring?
:M
I've read thru searches for mice, rats, wiring harness, &c. Didn't find anything to help.
Had to replace wiring harness in pickup back in February, big chunk of wiring eaten. Wrench recommended moth balls as a deterrent so put a pound in a nylon stocking in each vehicle engine compartment. Also kept baited traps in back seat of all but DW's car (Gkids), but never caught anything.
Now it's happened again, this time my commuter car, even with the moth balls (had maybe a half pound left).
  • rbtglove wrote:
    Had the same problem with mice with my riding lawn mover, they kept building nests inside and chewing the air filter and other plactic stuff. Fresh cab and Critter Ridder works for short periods but puting D-Con where they can find it is the only good solution. The bigger problems are the squirrels that caused a $1000 damage to my truck. I have tried everything to keep them away with no success. Can't find poison any the Squirrels and chipmonks to eat.
    as Joe Biden would say, "Buy a Shotgun."
    that will take care of your squirrels and chipmunks.
  • Had the same problem with mice with my riding lawn mover, they kept building nests inside and chewing the air filter and other plactic stuff. Fresh cab and Critter Ridder works for short periods but puting D-Con where they can find it is the only good solution. The bigger problems are the squirrels that caused a $1000 damage to my truck. I have tried everything to keep them away with no success. Can't find poison any the Squirrels and chipmonks to eat.
  • There are lots of preventative measures, most of which are ineffective. Like peppermint oil,mothballs, dryer sheets, a picture of Dick Cheney, etc.
    Mice like dark places. A light left on under the hood at night is a common, and effective, way to prevent pack rats from nesting and eating wires. Give it a try. A simple, low voltage light at the end of an extension cord will do. A friend direct wired an LED light to his battery. They draw almost no power and are quite bright. He said that did the trick.
    Good luck.
    Ed
