Dougalfamily's avatar
Dougalfamily
HELP !!
Good Morning, My name is John and I am brand new to rv's . I did a lot of research as my family and I have discussed full timing for some time. 9 months now. well The opportunity presented its self in the form of a job. that would require us to move. so we began preparing. we purchased a fifth wheel and truck after hours and days and months of research. a 2006 sandpiper bunk house. Needless to say that we couldnt get it quick enough. and the timeing has pushed us into a cornor. we had planned to set up the rv for month or so to learn it and pack it at our home. but time got us. Now i am on a steep learning curve and thought i was aware and comfortable with the systems at the walk through and after it arrived i realized very quickly i was not comfortable and very unsure of myself. I ran into some problems immediately.
1) hot water heater is electric and gas but our lp tanks came empty so i attempted to run it on electric. it never seemed to get hot.
2) the refrigerator. the temperature never seems to get cold and i saw no adjustment to make the necessary adjustments.
( its problems like these i keep facing)
3) i am a preventative maintenance junkie. when i buy something lie the truck i either know a bunch or have a have some one knowledgeable to teach me what and how to work on it myself. not so with the camper the first trip will be to our site for full time setup. the second comes a month later to northwest Arkansas for vacation. Please i need help in traversing this steep learning curve.
John
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Makes and models help a whole lot. For example there are two major makers of water heaters. Both are different in regard to how the HIGH LIMIT switch works
    With the fridge... There is a white plastic clip that SHOULD be attached to one of the fins in the Fridge compartment.. Move it up as far as you can. on the fin
    Do the fins get at least cold?
    Note takes 1-2 days to fully cool off.
  • OK Doug, rest easy my lad...
    First, just cut through the muck, and tell us only about the problem, not the situation. So, hot water tanks are easy to troubleshoot, but have you taken it off bypass. Is there water in it?
    Second, get some propane.
    Third, is your battery good. How many bars on the idiot light.
    Fourth, we presume you are plugged in... or on batteries?
  • 1. Breaker tripped, hi limit switch tripped, switch on WH in off position, or, the most likely, the heating element is burned out.
    2.Breaker tripped, control board bad, or again most likely, no 12VDC to the refer.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
