tenbear
Oct 07, 2013Explorer
escottd wrote:
Vet Man has the best idea. It would also be advisable after the clog is free to back flush again, then close it off and allow it to soak awhile. A preventative measure if not aware - Never open you black water valve while camping. Leave it closed and allow the tank to fill. Empty it only when it gets full, or before you break camp. That way the liquids will flush the solids along with them, reducing or eliminating the potential for clogging. It is also advisable to close off your gray water the night before breaking camp so you can build up a level as well. Then after you dump your black water, you can rinse the hose by flushing the gray water behind it.
If you are breaking camp before the tank is full and want to dump, add water until the tank is almost full, then dump.
About RV Newbies
