azrving
Apr 10, 2017Explorer
Upgrade the converter to something like a progressive dynamics that will go to 14.4 volts or one of the models that may go up to 14.8 volts. You will basically consider 12 volts as being time to recharge but you may want to charge before that if you have limitations on generator hours. The converter will go into float at 13.2 volts when the charge is complete.
About RV Newbies
