time2roll
Apr 10, 2017Nomad
Yes under light load you should be recharging as the battery hits 12.3 to 12.0 range. The lower it gets the higher the urgency. You will be restricted in Yosemite on generator run time. Best to start 2 to 4 hours before quite time.
To reduce generator run time consider replacing your converter with a PD9260-14.8
http://www.bestconverter.com/9200-148-Volt-Deck-Mount_c_227.html
Unless of course you already have something pretty good. Or if Dad has a portable 25+ amp portable charger to put direct on the battery would also work well.
About RV Newbies
