forhumanservice's avatar
Nov 11, 2015
Hi all..hitting the road in 2 weeks.
Hi all,
we are a family of 4 getting ready to hit the road cross country in a
couple of weeks. We have a 2002 Forest River Sierra 5th Wheel 27'
We are pulling with a 2014 Ram 2500 Big Horn.
Have just 1 question here to start
#1) We need to have a portable freezer along with us that needs to be larger then the small one in the rv (for medicine) it will be about a 94 qt 12V that also has a 120v plug as well. I know it will not be a problem while we are driving, but if we ever stop for the night at a Walmart, or.. can it run off the charged batteries until the morning?
Any experienced RV folks..can you tell us what you would do in this situation to make it work?
Thanks a bunch,
Dan
  • Depends on how well the freezer is insulated, how hot it is outside, how full it is, the current draw of the freezer, how many times you open it and for how long, etc., etc., etc. In short, no one could possibly answer that question. I would put some dry ice in it, keep it away from heat gain, and don't open it while it is running off battery power only.
  • I would go shopping for a large cardboard box that will take your freezer in it. Then go to the hardward store and buy enough rigid insulation to completely cover all walls, top and bottom, and back or front. Put the freezer into the well insulated box and try not to go into it except once every day or two to take medicine to the inside freezer. Open the freezer when you know you will have power to it, and possibly even turn the temp lower when you have power as well, then reduce the freezing when you are boondocking. Keep the freezer full, even putting in pieces of the leftover insulation to reduce the air space inside to what you need for your goods.
  • 1) What's the power draw (amps) on the freezer at 12V?
    2) How many and what size batteries do you have?
    You may find you need 4-6V golf cart batteries. That's just a guess.....
