There is some good news though, since you're butting up against the payload rating like I am. A weight distribution hitch, if you use one, will transfer anywhere from 20-30% of the tongue weight to the trailer's axles. Since I am planning conservatively, I calculated 20%.
So my formula looks like this:
Trailer weight loaded (max GVWR) / 100 * 10 = Tongue weight
Tongue weight / 100 * 80 = Final tongue weight on the vehicle
I forgot to mention, you also need to add the hitch weight to your vehicle's load, since most of the weight from the hitch, except the chain mounts/snap-ups, is on the vehicle. So every pound saved on your hitch goes a long way. If you have a lighter vehicle, the Andersen hitch is a good choice, at less than 60lbs. So is a Harbor Freight hitch. There are pros and cons to these hitches though; I encourage you to read the forum threads on this item before making that decision.
Be forewarned though, asking which hitch is best is kinda like a religious debate, or Packers vs Patriots vs Seahawks ;)
Any actual experience with a Harbor Freight WDH?Anderson HitchHarbor Freight hitches use a friction device, so read this too:
Friction anti-sway device use in rain or wet roads
