PawPaw_n_Gram
Jan 26, 2015Explorer
You can see from the floor plan that the kitchen sink is a bit away from the bathroom ST28BH
The black tank and back gray tank are likely behind the axles and the fresh water tank over the axles and the kitchen gray tank would be infront of the axles. They would have to plumb a forward gray tank because they would not be able to run the kitchen drain through/ around the fresh water tank.
Note also that the tank(s) are listed as Gray / Galley Water
About RV Newbies
