1st timer here. I parked in the yard on plywood; covered the wheels; emptied all tanks,new cover arrives tomorrow, all food removed and it's on household current shore cord. My question is this: Can ...
Your pipes and water heater need to be totally drained and anti freeze poured down the sink and shower traps. I blow compressed air through the system with both low point drain plugs removed. Takes me about 12 minutes. Also drain the fresh water tank. In my opinion anti freeze is not needed. Your heater would only heat interior. Not where pipes probley are. Best of luck
