path1
Jun 12, 2018Explorer
SoundGuy wrote:path1 wrote:
I'm thinking about installing a hour meter to keep track of hours between oil changes. Lots are available...but as with anything you buy some are better than others. Anybody have one that they are happy with?
If so what did you get? Make and model and how hard to install.
I just bought the first hour meter I found on Amazon, like this ... drilled a small hole in the top of the genset case, ran the sense wire through it, and wrapped it around the spark plug wire. It worked fine, was easier to see than Honda's blinking light system, and is obviously more accurate. :B
Thanks...i
I have your granny box design saved for future use
Thanks
About RV Newbies
