BarneyS
Dec 31, 2016Nomad
sonora wrote:Ava wrote:
It is the older converters that do not have a three stage charging cycle that are hard on batteries. The continuous charge on older units can boil the battery dry if not checked on regularly as far as I understand.
Would a mid 90's converter be an "older" one?
Yes,chances are good it is an older one.
If you would post the make and model of your converter someone will be able to tell you whether it is a "modern" one with the 3 or 4 stage charging circuit.
Barney
About RV Newbies
