rskrbina
Dec 31, 2016Explorer
afidel wrote:time2roll wrote:
If that modern converter is a WFCO all bets are off. Measure the voltage after a week and see if you actually see storage mode at 13.2 volts.
Regardless you still need to check the water level periodically.
See, that was my worry. It's a two hour round trip (during good weather) to my storage so the chances of me going during the next few months are pretty much nill. I think I'll pick up a timer and just set it to go for an hour or two a day which should be plenty to keep up with the small parasitic loss from the CO/LP detector and the stereo (or should I pull the stereo fuse?).
Hello Andy. Use your battery disconnect switch and you won't have to worry about parasitic loads while storing your rv.
Sorry, I read your post a little closer, please disregard.
About RV Newbies
