someuser001's avatar
someuser001
How do I get on air tv
I have an integrated tv and dvd system. It’s Jensen
But I cannot get the antenna on air to work. I did a scan but nothing works
I have tried changing the knob on the antenna and doing a channel scan. But that does not work
Any ideas?
  • OP, you seem to have a habit of asking questions and then never returning to the thread. Are you reading the responses?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Oh some diagnostic aid (You will need a volt meter
    Go toside (Up on the roof or beside it) and with the Ant-Switch OFF (led off) disconnect the cable from teh antenna.
    CAREFULLY Attach volt meter leads (You can hold the negative against the sheell of the connector with left hand and Touch the tip of the center wire with the positive lead. DO NOT SHORT wire to nut/shell) have partner turn on and then off. Observe 12 volts on meter (or not) if NOT you have a cable fault.
    Such as that connector in the roof I and one other I've worked on had to replace.
  • How old is that TV and/or the antenna?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Well first. Depending on where you are parked the answer may well be "You don't"
    Assuming a winegard Sensar III crank it up. Now there is either a box with many buttons or a "Switch plate" The switch plate has a switch. An LED a 12 volt outlet and an antenna connection.. The light must be ON
    On the Box of many buttons (BOMB) or Matrix Switch make sure the power light is on and select ANT for all devices.
    Next the TV.. It may have a menu option for ANT-Cable. Again ANT.
    And then scan.
    rotate antenna about 1/4 turn and re-scan (Take nowes on each scan)
    DO this again and again. Pick direction with best results then rotate to peak liek the #2 or #3 station strength wise
    Upgrades:
    I added teh WINGMAN to my Sensar III and later (after an oopsie) upgraded to a Sensar IV (turned out to be a genuine upgrade)
    I also replaced that wall plalt (well in my case added it) with a Sensar PRO which makes the entire Scan and peak bit way way easier.
    But there are still place where it just don't work
    Possible issues
    Been in one RV where there was indeed a wall plate.. but no antenna cables connected to it. Not a one. Prior owner had ripped 'em out
    Had mine fail once. At the roof line (in my case IN the roof) is a connection. IT was rusted shot. two new cable ends and a new double female (Barrel) connector and re-seal it up good as new
    And the Oopsie I mentioned that ripped it off the RV (ouch) One new cable end and a new head later it was better than new.
    OH and of course you need a Modern TV that accepts ATSC not an older analog job
    I have a pair of older DVR's they work on Cable and ANALOG ota but not with the modern Digital stuff. So they think they are recording satellite.. In fact the one I'm listening to as I type thinks it is recording Dish Network (DTV Pal by Dish Network uses genuine DISH remote codes) the one in the bedroom has a Zenith/ LG / Insigina adapter and uses different codes.
    THe two DVR's are chatty as well (Record on one play back on either or download and carry with you)
  • Its a powered antenna. you got to turn it on. there is a button near the 12v outlet that turns it on. a green light will come on when you do.. Then you can turn the antenna in any direction you need to.
  • Head of antenna needs to be AIMED at TV transponder Tower
    Antenna 'Booster' Button needs to be ON for OTA usage
    TV Input should be on 'air' 'antenna' etc
    Then Auto Scan for channels
    Several Antenna TV Tower web locators ....just put location and towers with available channels will be show with compass directions
    ** or point head of antenna same direction as other campers have theirs
    DTV Reception Map
  • Did you push the button on the antenna booster? It's likely on your coax connection plate
  • Is the “input” selected to over the air? You should have that option plus cable, DVD, HDMI and other. Is the antenna booster on?
