DrewE
Aug 30, 2021Explorer III
With moderate care and conservation and two people, I'd expect you should pretty easily get half the stay, perhaps a bit more. That's with taking navy showers and using real dishes, but being a bit careful not to waste water with either one and not letting the water run while brushing teeth, etc. The gray will fill up faster than the black, and with those tank sizes I'd guess the gray will be getting full about when the fresh water tank is getting towards empty.
Are you renting the trailer in-situ, or will you be pulling it? If the latter, you can simply pull it through the dump/refill station at the campground midweek; no need to buy a tote just for the trip.
If you take
If you take
About RV Newbies
