PawPaw_n_Gram
Dec 17, 2014Explorer
groundhogy wrote:
I only have a standard drivers license.
I am thinking if I go Class C or A, I will attempt to stay less than 30 ft in length.
The pull behinds really scare me but do interest me as I can separate the engine from the RV.
Should I start with a small RV and then get bigger?
groundhogy
Not a bad strategy.
Really driving them down the highway, trailer or Class A/C, is not really hard. And if you watch your turns - not too hard off the highway.
Parking on the other hand - backing it up - learning about overhead clearance, etc - are hard to learn if you've never driven a trailer much.
Some units, trailers and Class A & C - have a big swing of the rear end. Some units have 10 to 15 feet (or more) between the real axle and the rear bumper. My first trailer had about 8 feet, my current one has 14 feet.
I've measured, when I make a tight turn the rear bumper can swing almost four feet out from the track of the tires.
Backing up - never ever do it without someone watching behind you. Stop and get out and look if you have doubts.
Overhead - these things are much taller than you are used to. Watch out, look out, look up. You don't just have to worry about overpasses, you have to watch service station awnings, trees, etc.
Go slow - never rush. Rushing leads to broken RVs.
Practice, practice, practice, and make sure both adults in the rig (if there are two) can maneuver the rig. At some point, the 'non-driver' is going to have to do something.
It's your fault if the DW has to backup and you've never given her the chance to learn how to do it properly.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
