scrubjaysnest
Apr 01, 2016Explorer
2oldman wrote:korbe wrote:It's good enough for me.. as long as that voltage stays there when the charger is removed.
Well, I have been using my volt meter and measuring the readings in volts for a lot of years. Doesn't the volt reading measure state of charge? I must be missing something.
You can read about SOC hereSmart Gauge and hereBattery FAQ. Bottom line, most of us use voltage readings after the battery has rested 4 to 6 hours under NO LOAD conditions. It is a ball park reading.S.G. readings that are temperature corrected under the same NO LOAD conditions will get you into the infield of the ball park.
Another link on SOCBattery University
About RV Newbies
