ReneeG
Dec 17, 2019Explorer
NRALIFR wrote:
You might also check to make sure she isn’t leaving the black tank valve open all the time. That will cause problems for sure.
Bingo! When hooked up at a park, leave your tank valve closed and don't open it till you dump it prior to leaving. Leaving the valve open allows liquids to flow through and the solids to sit. You need all the liquids in it to move the solids.
About RV Newbies
