someuser001's avatar
someuser001
How to empty fresh water tank without pump?
My water pump is not working and I need to get it replaced.
Is there a way to empty the full fresh water tank without the use of a water pump?
I have 2018 Forest River sunseeker
  • Are you sure the pump is not airlocked and maybe not getting water to start the pump pulling water?
  • I've had to replace the flexible tubing between the tank and pump a couple times because it just wouldn't keep a seal on the barbed fittings any more. Air was getting sucked through the joints and was keeping the pump from priming. After replacing the old used tubing with some not new, but unused left over tubing I had that was still soft and flexible the pump was able to draw water from the tank again.
  • bukhrn's avatar
    bukhrn
    Explorer III
    Drain valve on my Forester is right next to the tank.
