dieharder
May 28, 2015Explorer
First, if you've never used it in 3 years, and you're in MN, then it's probably empty. you'll need to find the bypass and turn it so water can get to it.
Sitting for 3 years, you may need some replacement parts. Open the outside panel and have a look to make sure the propane delivery and the lighting element look good.
There should be a switch somewhere that you'll need to flip to turn it on, probably in the kitchen area. Mine is right beside the water pump switch, not sure if all are built similarly.
If you find the switch, I'd head outside right after I flip it and have a look over the heating area for the tank, just to make sure all looks fine as it lights (if it lights).
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
