poker620's avatar
poker620
How to use a DC to AC power inverter in an RV (RENTAL)
Hi,
I'm going to be driving my first RV in Iceland for 8 days. I want to buy an inverter so we can keep things charged on the way.
Here is the RV:
http://imgur.com/8jqKZ85
Will this inverter work ok? (enough watts, etc) It might be too late because the trip is soon but should I just spend ~ $35 and rent the inverter they provide instead?
http://www.amazon.com/BESTEK%C2%AE-Outlets-Inverter-Notebook-Motorola/dp/B004MDXS0U/ref=sr_1_1?ie=UTF8&qid=1431671160&sr=8-1&keywords=power+inverter
My main concern though, is how/when/where to charge things? I mean, does this RV have two batteries or something? Should I just only charge while the engine is on (like a car) or will I not kill the battery if I charge while the engine is off?
Thank you (I'm so confused) !
  • The battery on a typical RV will not power major devices for long. Some lights, furnace fan are fine. TVs definitely not. You can charge a laptop/phone. You don't want to run out of batteries during the night and be without heat!
    What I do:
    I use the batteries for lights only.
    I charge things as much as I can from the inverter in the truck while rolling. Mine is separate truck/RV.
    "cheap" inverters like the one you are looking at may not work 100% on all devices. Mine won't consistently charge a macbook; the light just goes off sometimes but it will charge iphones/ipads no problem. I think the laptop charger shuts down to protect the computer when the electricity is not "clean".
  • Use their inverter. Why drag along gear if you can rent it there for the same price? Their inverter will be set up for your use.
