RetSgt7114 wrote:
Forgive my ignorance, but do I understand this correctly? In order to use the generator on this rig, you must connect the shore power cable to the generator before turning on the generator? In my rig, I just turn on the gen and I get power inside. No plugging in any cable. Did I misunderstand?
Yes, your right. Our 06 Winnie, does NOT HAVE an automatic transfer switch, after disconnecting from shore power, you must plug the shore power cord into the generator receptacle, which is located in the electrical compartment.
Sounds like some breakers are tripped OR as said before the GFI has been tripped.
Beverley and Ken
