DrewE
Feb 26, 2017Explorer III
Class C's are not generally more maneuverable than class A's, especially for similarly sized units. The Ford E series van chassis (and, I think, also the equivalent Chevy to a lesser extent) has a pretty poor wheel cut angle, and when the chassis gets stretched for motorhome use it makes for a large minimum turning radius.
Some class C's do have better ground clearance and less terrible approach and departure angles than many class A's, but those things vary quite a bit from unit to unit. Some class C's (and A's) do have very limited departure angles that make hitting the back end a concern when entering sloping driveways and in similar situations.
About RV Newbies
