dodge_guy
Mar 02, 2017Explorer II
It definitely sounds like you should be purchasing. nothing wrong with an older RV. have it inspected. chances are the place that is inspecting it for you (the place the owner is using) will give you a fair inspection because they are going to want to keep your business also. I wouldn't hesitate to purchase used. take it on the highway for an hour or 2 before your big trip so nothing shows up at the beginning of your trip.
I wouldn't rent when you could buy. at the end of the trip you will not have an RV and will be out all the rental fees minus fuel. if you own, you will still have an RV at the end that you could use over and over!
About RV Newbies
