afveteran wrote:
Why do I need a water pressure reducer? ?
One of the campgrouonds where I winter has a warning on the park map about the water pressure, I think it says 112 PSI measured within the park
Straights State Park I saw the gauge hit 120 one day.
Some of the valves used in motor homes start to blow seals around 60
Hoses are not designed for triple digits either
Pressure regulators come in a few different types.. Most common at least in the stores (Which is a good place to leave them) are either plastic or brass cylinders, may or may not be adjustable may or may not have a pressure gauge on them and may or may not have a brightly colored grip on the female end (or wings on the body) the last being a High Flow, or High Capacity... leave them in the store.
Sur-Flow makes one, with various mounts, this is often used as the city water INLET on high end rigs... It also comes in an "Inline" model.
Unit comes with about a hundred different mounting benzels (You pick the one you want before purchase) OR.. With a male hose adapter on the output tube
THIS one I give about a 8 or 9 on the old 10 scale.
Valterra makes one I have never actually tried, but it gets good reviews.. has a gauge and an adjustment knob.
Watts and Zurin both make very good regulators.. The Very smallest WATTS may be too small, I recommend at the minimum a half inch size, Mine is 3/4" Zurin set to 50 PSI. Add hose adapters and.
Well, when I turn on the shower.. The needle on the pressure gauge does not even waiver, stuck on 50, like it was welded there.
They do get old and need to be rebulit, I have a watts 3/4 inch awayting rebuilt as well.
Both of these have a bell shaped brass housing with a bolt that sticks out where the bell would normally bolt to it's carrier (if it were a musical bell) that bolt is the pressure adjustment.
