Lantley
Jul 02, 2016Nomad
SoundGuy wrote:It an Epic event because you move hose 5 t.Lantley wrote:
I have a big Fat 42 Gallon Barker. I am one run and done. Emptying my grey is not an epic event.
I'm missing where using a few smaller containers rather than a large wheeled tote tank to off load and dispose of grey water is suddenly an "epic event". :h If anything, the smaller containers are much easier to deal with as they don't have to be moved at all as does a wheeled tote tank which must be tilted up when full and dragged over to the tow vehicle hitch, often over a soft ground surface that makes the task even more difficult. My GW Aquatainers simply sit in the back of the truck so if I use my FloJet Macerator to pump to them my only task is to later lower them to the ground at the dump station for emptying. If I instead gravity feed the Aquatainers, which in this scenario would be sitting on the ground at the rear of the truck, all I have to do is lift each one into the back of the truck for a trip to the dump station. In either case, hardly an "epic event". :R As for total capacity there's no difference as it's simply a matter of math ... my trailer happens to have a 30 gal GW waste tank so I have four 7 gal Aquatainers and therefore make no more trips than you would with your large, heavy, ungainly tote tank. :p
Screw on five lids etc. then drive to dump and empty 5 containers.
Each requiring lid removal etc. I'm worn out just thinking about it.
My 4 wheel tote requires no lifting to roll it. I make one trip and return back to my place under the awning!
About RV Newbies
