wkrp
Jun 06, 2013Explorer
The jacks you call leveling jacks are not that at all. They are for stabalizing only. For leveling, cut yourself some pieces of 2x6 or 2x8 lumber and use them under your tires on one side. Better yet, buy the plastic blocks that you can put together and make any size you need. You can get them at any RV store, Walmart, etc.
If you place two of the sticky levels on you camper, one on the front corner and one on the front side corner, you will quickly learn how much block you will need to get the unit pretty level.
About RV Newbies
