Chaz59's avatar
Chaz59
Is it ok to put cleaner in gray water tank
Is it ok to put a cleaner or a breakdown solution in gray water tank?
  • I don't know why you would..... It doesn't sit in there long enough to do anything. Just don't put grease, coffee grounds or food stuff down the drain and you will just have soapy water from dishes and showers. It's not a garbage disposal.
  • cleaner, why not? breakdown solution, what are you planning on breaking down? just don't put soap in there if you are going to dump on the ground.
    bumpy
  • If you can dump your tanks after you get home then you can do what I do.
    Dump tanks at campground. Add about a 1/4 tank of water along with some laundry liquid soap and some Calgon water softener.
    Drive RV home. Fill tanks with water and dump. This keeps my tanks from smelling and keeps the sensors fairly clean.
    Dave
  • Yes but, why? It's a holding tank.
    Google 'The Geo Method', it works for me.
