- MarkTwainExplorer
dfm wrote:
thehippie wrote:
Is it possible to drain waste tank without the sewer hose? Just let it drain to the ground
I know it's disgusting but will the waste like urine come out even without the sewer hose?
I'm not sure where You might want to try this , but if it is at a dump station I want You to be right behind me when I give it a try.
If it is at a campsite Then Again I want You to be the next camper in the site right after I give it a try.
Looking at your previous posts it appears You may be relatively new to the RV scene , But come on man, use some common sense and some consideration for others!!
If you will give all your neighbors permission to "whizz" in your patio area at your home every day, then I will give you permission to dump your RV without using a sewer hose:):):) - Bird_FreakExplorer II
C7XR7 wrote:
Sounds like he DOODY Trapped it. Sorry, couldn't help myself. :B
True story. When I purchased my 5th wheel the previous owner had the handle pull out on the black tank but the cap on the sewer line. Not a pleasant experience when removing the cap. Mierda sucede. - C7XR7ExplorerTrue story. When I purchased my 5th wheel the previous owner had the handle pull out on the black tank but the cap on the sewer line. Not a pleasant experience when removing the cap. Mierda sucede.
- Bird_FreakExplorer IIYes you can but you need to suck on the drain pipe when opening the valve to get it started. :S
- Johno02ExplorerYes, you sure can! Just be sure and look up inside the drain pipe to make sure the valve opens as you pull the valve handle.
- et2ExplorerSure you can. Just make sure you dumb the grey water tank after, it'll make it smell much better. Nobody will know the difference. :S
- frizzenExplorerYes it's possible. It's also possible to shoot yourself in the head with a .357 magnum and live. If you won't try the second, don't try the first.
- Mr__CamperExplorer
Before trying this at a campground, come home and try it one time in your driveway to make sure you have the correct trajectory and distance from the mark you leave on the ground. - TachdriverExploreroh the huge manatee
- old_guyExplorerit only takes one time to make a believer out of you. there are a LOT of stupid people out there. ignorance of the law is no excuse. IMHO you have to be an idiot to not hook up a hose. they might do this in a third world country but don't even think of it around here. if I saw some one doing that they would be visited by the law.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
