Iraqvet05
Apr 27, 2014Explorer
1. I cannot answer
2. Yes, even with the lowere humidity levels in the midwest, we get condensation on in the inside of the windows and frames. I usually run the A/C which helps to take moisture out of the TT but others have small dehumidifiers in their TTs.
3. How large is your grey tank? We have a 32 gal grey tank and our family of 4 usually fills it up in 2 full days while the black (also 32 gal) usually is a 1/2-3/4 in the same time. We try to watch the kid's water usage and take Navy showers (get wet, shut off the water, lather up and rinse off). As for the black tank, we just add 2 galls or so then drop in the chemical tablet. We only add water to the bowl if we need to go #2 as it helps from keeping the bowl from getting nasty. You may want to consider a portable tote if any attempts to lower your usage are unsucessful.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
