doxiemom11
Apr 28, 2014Explorer II
Regarding the use of water. If TP or solids are being flushed, water should be included to insure that when you go to drain the tank there is enough water to flush "paper and stuff" out. If you run out of liquid, you are leaving stuff behind which will eventually cause problems. #1 with TP - finish filling bowl with water and flush - #2 with solid and TP, finish filling bowl, flush - fill again and flush. 3 years of full-time using that method and we have not had any problems with odor or clogs. We do not use any chemicals nor do many full-timers as we have found out they are unnecessary if you use enough water. So I would go along with hubby's method of flushing.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
