wbwood
Apr 29, 2014Explorer
As far as the water goes, get yourself an oxygenics body spa shower head. It puts air in the water and you get more pressure with less water. Do as others mentioned, turn on water. Get wet. Turn off water. Lather up. Turn on water. Rinse and the. Turn off water.. You will save a lot of water that way. When we had outer TT it had a 64 gallon gray tank. Three of us would fill it up in a day taking showers and doing dishes. We weren't real wasteful, we just didn't turn water off while taking shower. Our current motorhome has a 30 gallon gray tank. We can go Friday - Sunday with all three of us with the oxygenics and being mindful food we use water.
With the black tank, you want to use a good bit of water, more so with poop than pee. If you almost fill a bowl up and flush, you shouldn't need to add more to it and dump again. It's like you are going twice as often.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
