bandit86
Apr 03, 2015Explorer
Bought some new double roller latches, the new ones seem to be holding twice as well as the old ones. Was looking at the ones I took apart, there was rust in the coil spring. A drop of oil and it worked a lot better, not as good as a new one but noticably better. I tweaked it with a screwdriver to take up the slack between the rollers and got almost 75 percent the strength of a new one. Installed the removed ones to double up some of the cabinets that had only 1 roller latch. One door beside the fridge has a warped door, couldn't get both latches to grip so I installed twist and lock type handle to keep it closed.
Still no fix for the sliding windows. Might drill through the plexy and install a push pin.
Took the radio console off, going to install a toggle switch to remove all power from radio so I can leave the battery booked up without worrying about them getting drained.
About RV Newbies
