westend
Feb 13, 2016Explorer
Solar modules have two phases (+) (-). Connect one wire from the module to each of the two correct terminals on the controller. You also need to connect the controller to the battery from the output terminals of the controller. Same reference, two phases. The color of the wire is not essential but conventional wiring schedule is dark wire = (+) phase, white wire = (-) phase. Connect the wires to the battery first as some controllers will self destruct if not connected in that manner.
You should also have two circuit protectors, either fuses or circuit breakers. I used one manual disconnect circuit breaker between the module and the controller. That allows for disconnecting solar power easily, should it be necessary. I used a fuse to protect the wire between the controller and the battery bank.
Good luck with your installation. If you have other specific questions, the "Tech Issues" section of the Forum has a lot of solar users ready to answer.
About RV Newbies
