4x4van
Jun 04, 2019Explorer III
As has been pointed out, there is no real need to be a math wiz or anything of the sort. The actual numbers result in some pretty steep slopes; 10" side-to-side (of the RV) is very extreme. 10" front-to-back (of the RV), while not as extreme, is still pretty significant, and easily noticeable.
If you can walk around comfortably, sleep without falling out of bed, and stuff doesn't quickly roll off the table, you are likely close enough. Measuring and bubble levels are fine, but if you simply look around your RV, and it is level enough to spend time in comfortably, then it's level enough for the fridge.
About RV Newbies
