aftermath
Jun 12, 2019Explorer III
midnightsadie wrote:
only time you MUST TURN OFF is when fueling or you could be on the 6pm news.
Ah, and here it is. Another ill informed statement aimed at frightening people into a needless choice. This continues to be my number one pet peeve. I will ask midnightsadie to provide any link to a fire caused by leaving the fridge on. I did see one where an elderly gentleman lost control of a gas nozzle and sprayed the side of his camper van, not a trailer, where the fridge was located. Yes, it went up in flames. The next time you fuel up, take a look at where the gas hose is located and where your fridge is located. Mine is a good 20 feet or more away and on the other side. It is also located pretty high up on the side of the trailer. Gas vapors are heavy and will sink to the ground. The chances of such fumes reaching the fridge with enough concentration to erupt in flames is.....well....near impossible.
AS far as level goes, 3 percent means 3 per hundred. 3 inches in 100 inches, or if you have a 25 ft. trailer, 9 inches in 300 inches. So, if you are more than 9 inches out of level then you might have an issue with your fridge. My dealer said that if you are comfortable sleeping and walking around the trailer then you are level enough. To think that you have to be spot on with your bubble is simply wrong.
About RV Newbies
