Grampa_TExplorerMay 30, 2013Leveling blocksOur class C has dual rear wheels. When we are parked at a site, do we need to place leveling blocks under both tires on each side, or is it acceptable to block up just one tire?
JESTER7406ExplorerMay 30, 2013I use 3/4" plywood with a handle cut in it. I put a block under both rear tires if needed. Then use hyd levellers
Related ContentLeveling Blocksleveling blocksLeveling blocksTurnbuckle blocks gas capLeveling Blocks???
