I'd spend the money and install a septic tank to hook to. Figure out where your house will be and get a tank in the ground. Then you just need to deal with fresh water/propane/gas.
Skirt the trailer with insulating material. When I lived in mine for two years (full hook ups), I skirted with thin OSB backed with 1" styrofoam sheets. Take it a couple inches into the ground and to the edges of the trailer to help eliminate rodents and bugs. Make a small access flap or door for draining your holding tanks.
Have a lot of gas on hand for that generator for temperature extremes (hot or cold).
