DrewE wrote:
What kind of an LP tank?
No need to complicate the issue :R ... considering the OP's SIG says he has a 2016 Kodiak 172e Hybrid it should be obvious he has a conventional "barbeque" propane tank on his hybrid. :W
To the OP ... if you have dual tanks just don't worry about it, when one tank empties you can revert to the second. If you have just one tank consider adding a second with an auto changeover regulator. Alternately, if you consider propane reserve a concern you could swap out your steel tank(s) for
composite tank(s) that will reveal their content just by looking at them. :)
