Raife's avatar
Raife
lug nut socket
So likely a basic/noob question, but I want to carry the correct sized socket for my lug nuts on my trailer and tow vehicle tires...will shallow sockets work or do I need deep sockets?
Thank you.
  • rhagfo's avatar
    rhagfo
    Explorer III
    BarabooBob wrote:
    Both my TT and my F150 require thin wall deep well sockets. Harbour Freight had them in 1/2" drive. I also bought a 30 inch breaker bar. The darned truck requires 150 lb/ft of torque and removing the lugs after they have been on a while takes some serious pull.
    My TT required 100 lb/ft on the lugs.
    Both units have aluminum wheels.
    Interesting that is the same torque as the wheels our Ram 3500 DRW. I have on board air and carry an impact wrench.
  • Thanks. I bought some thin wall, deep 6-point sockets. The set will cover my trailer, my tow vehicle, and all the bolts on my equalizer WDH. I already have a 2' breaker bar, but also have an 18v impact wrench to help.
  • Both my TT and my F150 require thin wall deep well sockets. Harbour Freight had them in 1/2" drive. I also bought a 30 inch breaker bar. The darned truck requires 150 lb/ft of torque and removing the lugs after they have been on a while takes some serious pull.
  • Bobbo's avatar
    Bobbo
    Explorer III
    I bought a thin wall, deep well socket to fit my lug nuts and a 2' breaker bar. They ride behind the rear seat in my truck. That is in addition to a cross-arm lug wrench and whatever Ford put there.
  • Change a tire in your driveway using only tools from the trailer and TV. Then you’ll know you are good to change a tire at night, in the rain, wind, cold etc. Consider a home built ramp.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The socket will fit either way but some suggestions
    Get two. one "Thin wall" (you might want a deep for that) to remove the Simulator (Wheel cover) nuts
    The other standard but also get an extension shaft so you can clear the blasted dual rim.
  • Try it . I had the correct size but the wall thickness of socket would not fit in the well .
  • I use a short impact socket, 6" impact extension, and my old Craftsman torque wrench from the 1970s.
  • Standard length sockets will fit most lug nuts. I carry (2) 4 way lug wrenches, one in standard and 1 in metric to give more leverage when removing lug nuts. I also carry a torque wrench and (2) 6" extensions for it with the correct size sockets for the truck and the trailer lug nuts on each extension in my truck tool box so I don't have to hunt for everything.
