wa8yxm
Jun 21, 2014Explorer III
ChooChooMan74 wrote:
We have a brand new system. The vent on our system is in the leaching field. You don't want to start pumping solids into the leaching field.
Now I know the reason for the vent stack... And putting it in the leaching field would.. Well,,, it can not do it's job there... That is unless it is one of at least TWO vent stacks.. then it might work,,, But I doubt it.
The vent is there for two reasons.. One I'm sure you can figure out
The other is vacuum breaker,,, IN another time and place we are arguing if the Sewer Solution is a jet pump (It is). Imagine you flush your toilet... The swift rush of water will suck all the water out of the drain traps in the house... SO, they put in a vent, to admit air, and let the traps remain ... trapped.
About RV Newbies
