SoundGuy
Dec 09, 2017Explorer
rvshrinker wrote:
I could also carry an extra tank, but how do you lift that heavy thing into the truck bed? The aquatainers is another less elegant solution.
Why is the Aquatainer a "less elegant solution" when it's a solution that completely solves your grey water problem? :h Believe it, regardless of the size of your grey water tank it's going to fill while you're still camping so you will want an effective means of off loading the contents - Aquatainers are that effective means. ;) If you don't want to lift a full 60 lb Aquatainer into your truck bed then instead pump grey water into Aquatainers already sitting in the back of the truck. K.I.S.S. ;)
About RV Newbies
