path1ExplorerApr 19, 2018making 12 volt connections better12 volt connections... in your opinion what is the best? In the past I've used these linked below. Is there anything that makes a good connection and is removable? Thanks https://www.delc...Show More
AvaExplorerApr 19, 2018Where possible I use solder and heat shrink tubing to make a secure connection.
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsMaking OilTrailer connectConnections, connections, connections ??????
