path1ExplorerApr 19, 2018making 12 volt connections better12 volt connections... in your opinion what is the best? In the past I've used these linked below. Is there anything that makes a good connection and is removable? Thanks https://www.delc...Show More
Farmboy666ExplorerApr 19, 2018I use ones that have solder in the middle and heat shrink, heat with a heat gun and it's soldered and sealed in one step.
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsMaking OilTrailer connectConnections, connections, connections ??????
