Golden_HVAC
May 17, 2015Explorer
So you are counting that your RV is perfectly balanced side to side?
I would be running 100 PSI in all the tires. If you like running more than 70 MPH, then increase the pressure an additional 10 PSI, so that the tires will run cooler.
Chances are that the drivers side slide outs would make that side heavier than the other side.
Fred.
Fred.
About RV Newbies
